dhargrover
Thread starter- Joined
- Sep 22, 2007
- 3
I'm having trouble starting my engine. It acts as if the battery does not have enough power to crank the engine, but if I remove the spark plug from the bottom cylinder, the engine turns over just fine and will even start and stay running without that spark plug being in there. There is also tons of I assume fuel, more than normal that discharges out the spark plug hole while it is running. Sometimes I can manage to get it started with the spark plug installed in the bottom cylinder. This allows me to test the ignition of the lower cylinder. I can feel the spark in my arm when I touch the cable, also the engine doesn't feel like it is missing any when I disconnect the spark plug cable. I've swapped spark plugs and it's always the same. It doesn't appear that the spark is firing inside the cylinder, but there is spark on that wire. I'm no mechanic, but the best way I can describe it is that it seems what is happening is that somewhere a large amount of fuel or fuel and water is getting into the lower cylinder and somehow not allowing the fuel to ignite in that cylinder. The large amount of fuel in that cylinder also seems to be really locking up the engine when it is trying to start, almost as if it is completely full of fuel and because of the compression on either side of the piston, it doesn't move at all.
Something else that happens is that after the engine is running for a while, the fuel line develops a vaccuum and essentially collapses so that there is no longer any fuel getting to the engine. The two may not be related.
Thanks in advance for any advice.
