need mech. adv. springs (they're broken)
floater3
I have '84 volvo 5.7 with I believe a Prestolite distributor. The advance springs are both broken. Where Can I find these??? If I go with a electric conversion kit, will I still need them? (its a point type distributor). Thank You.
thrasher
Re: need mech. adv. springs (they're broken)
It will depend on the type of electronic ignition that you fit, but the vast majority will need the mechanical advance to work correctly, so yes you need to fit new springs..
Sorry I don't know where to get the parts..
Gary
JustJason
may take some digging around and they may have to order them but a napa is a pretty good bet
tommays
Without out a shop that can spin up the DIS and test that the advance curve is correct with the new springs it can be very hit and miss even if you find OEM springs
Tommays
djvan
If you can find them you are GOOD. I looked for about 3 months and finally replaced distributor with a delco remy.
Found several "Oh that's the same spring as in --------" but without being able to spin the distributor and check the curve against the specs, I didn't feel comfortable going by "he said she said" info.
Now maybe if you live in a big city, check out the local "hot rod" shops they may have a way to spin your setup and get you springs.
DougV>
Robj
If you cannot finf a shop to check the advance curve, how hard would it be to install the springs yourself and then check the curve? How I would do this is at 500 or even 1000 rpm increments check the timing, maybe up to 3500 rpm, note the advance and then plot it on a graph versus rpm. You would need to know what the specs are to compare, and getting that information may be the hardest part. So if you find the right spring, do this little test to ensure it is the correct one. That is all a distributor shop would do.
Have a great day,
Rob.
