high performance gear lube
baconbiscut
Where can I get this stuff. I can't seem to find at wal-mart. Is there any equivalent oil or any other place besides west marine that i can get the right oil thanks dan
Re: high performance gear lube
I run Mobil 1 in 75W-90,....... Found in Most auto parts stores.......
ziggy
i get it at my local mercruiser dealer......
wire2
Do you feel it's as good or better than Merc Hi-Performance? I have lots of automotive outlets local to me but nearest Merc dealer is 20+ miles.
A Full Synthetic Oil is a Ful-Syn Oil......
Merc Hi-Per is a Ful-Syn oil......... So is Mobil 1.....
Other than the Color,...... I see No Differences......
And,....
I Do Know that Mobil 1 will hold Alot of Water,+ yet still provide Excellent Lubricating properties......
baconbiscut
can I mix mobile one oil and high performance. I was told not to mix with the premium and high performance. but does that apply to the mobile one oil and high performance gear lube.
We're only talking about a Qt.,+ 1/2 or so.......
I'd drain it,+ Fill it with the Oil of your choice,..........
Rather than Mixing any oils....
baconbiscut
No this is for a bravo one drive the oil is going down to the add mark. The motor and out drive are new a total of about 6hrs on both.
rodbolt
my merc rep told me the merc HP lube is a semi-synthetic. forms mud at the bottom of the resevoir as the anti-wear additives settle out, the resevoir needs cleaning at least once a year or it clogs.
if this is a new application adding a few ounces is normal, if its over 20 hours its NOT normal.
dunno about mixing them, I just plan ahead and have the syuff on hand when its time.
I normally tend to use what the book calls for or what the book says the equivalent is.ie:GL-5,GL-4 so on so on.
the volvo GL5 and the mobil GL-5 are compatable, most likly refined by mobil anyway at half the cost.
these oils all have SAE specs. as long as its in the correct spec its ok.
but to answer your compatibility question? beats me. never tried it. the bravo's and the VP's both use a cone type clutch so I dunno.
