I am trying to determine model of my OB I believe the yr is at least '93.The sticker is not on the bracket.
Its a 150 Hp Spitfire with optical ignition it also has the shift interrupter switct on the throttle/shift linkages.( weren't on 91 & 92).
There is I believe a serial # on the Freeze plug: G3088017.
P/N on Powerpack is 584990, rect./reg. 548093, and coil 583740. I was using these #s to attempt to cross reference. Does anyone know what model is based on the serial number? Is there any other way to know? Much thanks in advance.
