Evinrookie
Thread starter- Joined
- Aug 20, 2007
- 100
I have a 1967 Evinrude 80 Hp and was told that the standard suction cup style muffs won't work on my engine. The guy I had rebuild my starter showed me some antique piece of twisted metal with a hose fitting that he uses for older engines.
As of right now, the only option I have is to remove the hydrofoil the previous owner put on and run it in the hugely oversized trashcan my city makes me use. It would probably take me a good 20 minutes to fill it to the level I need and then I've a huge heavy bin full of water to dump (and nowhere to put my trash).
I know a test tank is the preferred method for working on an engine because it puts a load on it and makes it less likely to run away. However, I would prefer to something a little faster and easier to deal with.
I don't want to haul down to the lake and find a starting problem that I need to fix on the ramp. I also doubt the fish or the EPA would appreciate me decarbing my engine out on the lake. Does anyone know if the muffs will or will not work on my engine or what alternatives there might be?
