Pressurized Fuel Tanks.
Trackbolt
I got to working on the two six gallon pressurized tanks this morning and I am at a crossroads. I have the pressure assemblies gear off of the tops of the tanks and was scrubbing the insides with some Scotchbright on a drill extention. The tanks have been empty and cleaned out for quite a few years. There are no fumes present. There was some rust in the bottom of the Johnson and I found two pinholes. The Evinrude tank has a clear bottom but the sides have a light coating of rust which will definitely find its way into the fuel systen no matter how well I get it clean. Right now I am leaning toward abandoning the pressure fuel system and installing a fuel pump. Cost wise I will be ahead of the game. Experience with old tractor gas tanks tells me that once you plug one hole there is another right around the corner. I don't know how a "slosh and seal" compound would work on a pressurized tank either. Any Ideas? The motor is a 1958 Evinrude Bigtwin 35. I am leaning toward two metal OMC tanks to keep the "look". Wasn't OMC transistioning from the pressurized system to a pump system in the late Fifties?
Thanks
Tony Mig
tashasdaddy
Re: Pressurized Fuel Tanks.
it was an option then, i have a permanent post at the top of this forum telling you the proper way to convert the motor. this was on a 58 35 hp johnson, the same motor.
tmcalavy
Unless you're really in love with that pressure tank, consider the fuel pump conversion. Less than $100 and very little time involved. I've done three old Johnson/Sea King 15-18 hp outboards this way. Now I can grab any tank/hose in the shop and any outboard and be on my way.
freddyray21
I am about to do the same thing with a 58 18hp. The pressure tanks can be a pain in the ***. imo
