Idle Mixture Issues...
gregstukey
So, I was adjusting my idle mixture and now I'm getting excessive exhaust, a lot of black exhaust residue under the swim deck and on the transom along with a lot of crud in the water. I was wondering if this meant I was running to rich or lean and how to fix it. Also, I was wondering the relationship between the idle mixture and idel speed--are they relatively independent of each other or do they work together exclusively? I'm trying to obtain a better understanding of these two screws...
Thanks,
-Greg
1992 Cobra 5.0 V8 with a Holley 2 barrel.
180shabah
Re: Idle Mixture Issues...
in
You need to get a shop tach, vacuum guage, and a manual, then all will be clear...
gregstukey
have manual oem cobra---still not too clear on the relationship...no tach but anyway, ...just want the smoke to chill out... if i adjust the mixture does that mean I HAVE to adjust idle speed---or when mixture is good set my idle speed last? the latter makes more sense to me but like I said I'm a little hazy on it...
180shabah
Adjust mixture
adjust idle speed
set timing
readjust idle speed if needed
All of this is on a warm engine
Silvertip
If the engine is making that much black smoke I doubt it's an idle mixture issue. Are you sure the choke is open?
gregstukey
its not so much "black" smoke as it is excessive exhaust and yes, choke is choking...
gregstukey
the boat was performing great before I messed with it. no smoke and ran smooth. I shouldnt have messed with it but I did in an effort to understand my boat a little better (backfired). im just trying to get it back to where it was...
MikDee
Banned
When warmed up, Adjust mixture screws to the highest engine rpm, that's it! Then adjust idle speed screw to specified rpm, you're done.
Ayuh,................
Life at the iboats forums in 1 sentence.......................................:D
gregstukey
yep....i duffed it. shoulda left it... such is life...
