FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
How much water needs to be comming out of the telltail ? my stream is less than it usted to be , and I just has the morot serviced for this problem, but its not as strong as it was
Re: 50 hp mercury , how much water out the tell tail?
you could have a piece of impeller in the system somewhere. Many times a piece of rubber will break off and go up the pipe and into the power head and may be too big to get out the pee hole and just sticks in there blocking water. Try some weedeater line back through the tube and see if it comes out stronger. If not, I would pull the lower unit and back flush it and make sure the water tube is clear. If the impeller was replaced It shouldn't need a new one, but........you do have the lower unit off...........Jerry
Jack, many places that service engines run them on a hose, if thats the case the water pressure from the hose covers up the pump problems, it sounds like time for a impeller
