steelespike
Thread starter- Joined
- Apr 26, 2002
- 19,069
As everyone knows I'm an Etec fan.
I was doing a little research and was surprised at the Etec prop sizes.
I know gear ratio enters into this but the Etec surprised me specifically on pontoons but also more normal applications.
In a brief look I only found 2 Etecs And a 50 Merc. bigfoot.
Big foot is 2.33 gear ratio. I picked the Merc because the gear ratio was closer to the Etec.On a 20 ft Duracraft pontoon 1620 lbs. prop is a 14 X 9 aluminum. made 18.9 mph at an impressive 4.2 gph.5325 rpm.
The 50 Etec 2.63 stock ratio on a 20ft Premier 1,800 lbs.prop is an aluminum (this is impressive) 14 X 13 made 21.1 mph at a slightly less impressive 4.96 gph.5,500 rpm
Same motor on a 23 ft Maurell pontoon 2,455 lbs Stainless (also impressive) 13 3/4 X 13. Made 19.5 mph at a not to impressive 5.16 gph.
5,375 rpm.
Not sure what all this says about slip,torque curves etc.But in just the prop size I think the 14X13 on a 50 hp pontoon is impressive.
I also think I have too much time on my hands.
5,375 rpm.
