Brimauster
Thread starter- Joined
- Jul 4, 2007
- 28
So I have decided to get the Ford Ranger to be the tow vehicle for me. I've read a lot of opinions both for and against this little truck, and I believe it will suit me fine. I will be towing a 19' aluminum boat with a 135hp I/O on a single axle trailer.
The total weight of the boat-motor-trailer package is 3332#. Add in 34 gallons of fuel at 6.3 Lbs/gal, and the weight goes up to 3547#. Batteries, (2) another 150# or so, add in some gear and coolers and I'm now up to around 4200#. The GCWR is 9500#, so 4200(trailer) + 4760(truck) = 8960# which is a slim 540# under the GCWR, close, but within the limit.
The Ranger's towing capacity is as follows: (all info is direct from Ford website)
4.0L V6 - 3.55 axle - 4X2 - Auto - Reg. cab - 7' bed = 6000#
4.0L V6 - 3.55 axle - 4X2 - Auto - X-cab = 5860# (3.73 axle not offered on 2WD)
4.0L V6 - 3.73 axle - 4X4 - Auto - X-cab = 5560#
I've read quite a bit about the 3.73 and 4.10 gears in the rear axle being the optimum choice for towing, but why then does the 3.55 in 4X2 have a higher rating than the 3.73 in 4X4? I would guess its because the engine has to give power to the front axle in 4X4 mode?
I would say that 95% of my trailering would be within a 30 mile range, with a few small hills. And maybe once a year a long haul up to Lake George, ( 350 mi round trip).
I will be using this truck as my daily driver as well as towing, so the 3.55 looks good for mileage. Is the 3.55 4X2 an acceptable choice for a 4200# load? I know some will say go with the 3.73/4X4 for those slippery ramps, and rightly so... but do I really need it?
