seadoo SP electrical problem
fishmonger.33
i have a 1992 SP. it has no spark right now. can anyone tell me what is up, is it the relays, or the ignition coil?
thanks
fishmonger
and how much are new relays?
Rob454
Re: seadoo SP electrical problem
It could be anything from the CDI unit to the stator, the pick up or the coils themselves. make sure your ground cables are on tight and no corrosion first.
Both cylinders or just one?
Rob
fishmonger.33
both cylinders. i had the same problem with my Xp same year, i had no spark, replaced the ignition coil and it was fine. the previous owner said somthing about switching the relays around and he got spark intermitantly, but i dont think this is possible, is it?
Jeff Walkowiak
with the lanyard off the kill switch// hold the button all the way down with your finger and crank the engine, see if the plugs fire, if so you have a bad lanyard cap and it is killing the ingition.
fishmonger.33
its not the laynard. i tryed that already, i checked the ground wires, fuses, plug wires, and no spark
