Dante04SRT
- Jun 30, 2007
- 311
Title speaks for itself. Is there a standard place they are located?
The Merc 3.0L engines have never come with a water seperating fuel filter as OEM equipment. If there is one, it will be located by plumbing between the fuel tank and the engine fuel pump. Follow the hose, if there is one it could be anywhere (including the transom).
If you follow the hose from the engine to the tank and don't find one, you don't have one and should install one.
I believe my only fuel filter is located on my carb. i have a 87 3.0L merc. I dont see anything else on the pressure side on the fuel system. Its the large nut located where the fuel goes into your carb. Remove the fuel compression fitting remove the larger back nut off carb and Abracadabra, a fuel filter.
Why don't you get a service manual. All these questions you have on this forum are easily answered by looking in the manual.
Is this an old style porous filter
Now I just need some pipe sealant to replace my fittings on my carb
