I have read a lot of the threads with similar problem but I need help with my 1992 120HP Force. It runs fine except when I cruise at half throttle to WOT for a sustained period (15 minutes or so). It will then begin to run rough and then bog down. When I begin to hear the engine run rough I change to WOT then idle a few times and it seems works its way out of the problem and is ok again. When it is bogging down the fuel line bulb is hard, I have squeezed it and there is no change (I replaced the fuel line and bulb from tank to engine). Choke has no effect. Took it to a dealer and they found nothing. Any help would be greatly appreciated. Thanks
