Fiberglass questions!!
danstroup284
Ok, I have done the "search this forum for information" already but still need some guidance. I have recently torn the floor out of my 89 Celebrity (and a dash and a storage box) due to rot. Getting ready to make templates from cardboard and start the wood work. I am going to use 5/8" ply. Planning on fitting it and then covering the cut wood with a resin/hardener mix. Then after installing, glassing the floor in place.
Here is where I need the specific guidance:
1. I do use the hardener when sealing the wood, right? Wouldn't work as a pure resin soak would it?
2. What type of cloth/mat should I use on the floor? And should I do multiple layers?
3. I have left the original tabs and will glass into them. I am thinking that I will have to use the tape that I see is available in different widths. Anything to worry about in this department?
Thanks in advance, and pics will be coming soon!
Dan
Re: Fiberglass questions!!
Dan, Without hardener, the resin will not set and get hard. It will therefore be sticky and unsuitable. You can add less hardener, and it will allow more time for the resin to soa into the wood. Also, coat all surfaces of the wood with resin/hardener.
After the new floor has been screwed to the stringers, cover the whole floor with at least two layers of light cloth and three coats of resin/hardener. Overlap the seams and the tabs
gcboat
1-1/2 should be plenty. With a couple of applications it should be good to go. :D
ondarvr
What type of resin are you using, epoxy or polyester?
sdunt
3. ... I am thinking that I will have to use the tape that I see is available in different widths.
The difference between cloth and mat is that cloth provides more strength, mat is more 'water proof' I used 7.5 oz clothe from this guy: http://stores.ebay.com/Tordoff-Supply
The pieces he sells are ends of rolls, very reasonable.
As for tape, if you really feel the need for the strength of a Bi-axial material at those joints, then yes you can use tape. You can also make your own "tape" from cloth: http://www.shareaproject.com/pages/imageDetail,p,148,i,2873,00.html
danstroup284
Thanks again for the help. Headed out to salvage cardboard today and get started with the template for the floor. Got to get more pictures taken and find a place to post them. When I do I will start a new post.
Dan
danstroup284
Probably gonna use the epoxy. I don't know much about this stuff, but it seems that although more expensive, I would get a better seal and added strength with the epoxy.
Am I wrong in this thinking?
Dan
danstroup284
Wow, just looked at the US Composite site and am thinking I was a little rash to decide on the epoxy resin. Perhaps the poly resin (given it's price difference) will be the better route. And probably easier to obtain locally.
ondarvr
You can even get polyester resin at most Wall-Mart stores, so it is easy to get. Epoxy is stronger and is an all around better product, but polyester works just fine and when used correctly (neither product will last long if not done correctly) will last far longer than your need for this boat.
