lexkyboater
Thread starter- Joined
- Apr 9, 2007
- 191
Re: Replacing clear coat with gel coat?
The Nylene is available at Stokley's Marine in Nicholaville, KY. They said they don't know of anyone else that carries it, have it specially made for them for the houseboat industry, and they ship it all over the country. Check them out at http://www.stokleysmarine.com/. They say the manufacturer is Nylene out of New Jersey, but that they make it for Stokley's, so I'm unsure if you can get direct from manufacturer. If you end up going this route, please make sure and post before and after pictures for us, to let us know the results.
I'm unsure on the sanding of faded gel coat. I can tell you that you have to be careful, because if you sand any of the gel coat surface you'll be looking at silver metal flakes that no longer match your paint color and the rest of the colored metal flake. Stokley's says they hand sand everything on gel coats, and don't use any power tools, but I'm tired of sanding by hand and will probably end up painting it anyway since so much of the right side has so much silver metal flake showing. My understanding is that all of the flake is silver, it just has paint covering it that makes it look maroon or other colors.
Also, if you're saying you have dull gel coat colors, that sounds like oxidation, and sanding helps that, or if the clear coat is gone, you might lightly sand then use a marine oxidation remover. Just be prepared if you're sanding that it's going to take a while, a long while. Stokley's also tells me it's usually $4000 to fix gel coat due mostly to the time in labor it takes, and I get the impression most of that is sanding/prep time.
