How do I tell which model of motor I have
Delby
Hi again I have a 1971 johnson 100hp and I have found the part I need but they need to know which model number I have either the 100ESL71C or the 100ESL71C anybody got a clue on how to determine which one I have or where to look . Thanks Delbert
BoatBuoy
Re: How do I tell which model of motor I have
Is this a trick question? The 2 model numbers you posted are identical. But to answer your question, the model and serial numbers should be on a boilerplate tag somewhere on the transom clamp. If not found, there should be a quarter-size welch plug somewhere on the block close to one of the heads. If you find it, the model number may be stamped in it - not sure what years that was done.
Delby
I'm sorry about that i've never been that good at typing.It was supposed to say 100ESL71C or 100ESL71A and the tag on the clamp is gone and the quarter size little plug thing say's J3505745 Thanks Delbert
F_R
If the tag is gone off the bracket, you are scrogged. The other number is only the serial number. I suppose the part you need is something they would have to special order and can't just match it up?
Delby
I guess I'm screwed cause the place is sea-way marine and it's probably in CA. and I'm in UT. Thanks for all the help. Delbert
ezeke
Maybe not such a problem, because there are only two models, and the parts are all displayed on the BRP parts catalog site for both models.
Whatever you need is either the same for both models, probably 95%, or will be clearly defined in the parts diagrams and parts lists for your particular model.
http://epc.brp.com/default.aspx?brands=ej&lang=e
Delby
Thanks a bunch for the web page.I exploded both models and the pics look the same.It's the foward gear by the way. Thanks Delbert
