'73 electric shift lower 35, 40, 50,---compatible with '81 J35RCIG rod shift?
rebuilt
Can I make it work? Can I just use a shift rod instead of the electrics? KR
rebuilt
Re: '73 electric shift lower 35, 40, 50,---compatible with '81 J35RCIG rod shift?
As an afterthought, the pics look exactly like what is on my other motor now. Apparently, the lower on my working motor is from a larger setup. The only difference between the two is that on the 73, there is a small extrusion of aluminum at the rear of the cav plate. It's about 3/8" wide, maybe 1 1/2" long and points downward toward the prop. Thanks, KR
