two battery
isis
If i hook two battery in series( neg. to pos.)would i still have 12 volts and is this okay to run your outboard like this?
steelespike
Re: two battery
No that would be 24 volts. negative to negative positive to positive is parallel.
for 12 volts.You could put batteries in series and use one for 12 volts.
millercm1
Re: two battery
Hello, I am curious of how to hook up two batteries togather on my outboard. But I don't quite get it, can you explain further?
:D
bowhuntrrl
Re: two battery
:D
Best way is to buy a battery isolator switch. That way you can either run one or both batteries.
ricksrster
Re: two battery
Silvertip
Re: two battery
It would really help if you explained in more detail what you want to accomplish! Do you want one battery for starting and the second as a backup? Do you want both batteries on-line all the time? Do you want one battery for starting and the second for a trolling motor and accessories. All of these options have many different wiring possibilities.
