skynyrdcat
Thread starter- Joined
- Mar 11, 2007
- 157
88 Evinrude 110 HP V-4
I marked TDC for each cyl to check timing and with a light found the #4 is firng 2 times (at right time and at same time as #3)
Any thoughts on what causes this?
Fresh after a rebuild (didn't have engine before so I don't know if it did this before I rebuilt).
I have new plug wires, plugs and power pack but used old charge coil and sensor.
I moved all the wiring around and couldn't find any short, also checked them for grounding with an ohm meter.
