torque value for a flywheel nut
fredskid
Good morning,
Having suscessfully mounted My new used timing belt, it's time to torque the flywheel nut. My question is does anybody know, how many lbs for a 1965 75hp johnson flywheel nut, and could you tell me please? thanks for all your help so far. While I've done many things by trial and error, it simply great being able to ask questions of people who have already been there. I thank you for all your help....,mike
tashasdaddy
Re: torque value for a flywheel nut
my 71 says 75-80, but i've seen them as high as 120. so i wasn't much help.
fredskid
Thanks It's a start, I don't think that they changed things that much back then, so i assume(there's that word) it's close. I'll wait and see if someone knows for sure, is there any problem in over torqueing it a bit say 90, or is that worse?...,mike
F_R
It's 70-85 for your motor. Don't over or under torque it. Over torquing will spread and destroy the flywheel. Under torquing will shear the key and the flywheel will spin on the shaft and gall it. And make sure the shaft and flywheel tapers are clean and dry before assembling..
tashasdaddy
he's the man that would know for sure. there's you answer.
fredskid
Thanks for all your help, again!! 70 to 85, clean and dry tapers, 10-4. So far so good....,mike
