FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
ok I jumped the connections and poured some gas in the carb this morning. . it turned right over and ran til i shut it off after a few mins. . then i put the relay back in and started it again without adding gas and it ran fine til i shut it off again. . let it sit another 15 mins and started it again and it fired right up. . . So what the heck does that mean??? other than it works again for some mystery???
Means your accelerator pump on the carb isn't working. So it's not able to prime the engine with gas to get it started. If you let it set overnight, it probably will not start again in the morning unless you prime it with gas again. Since it does keep running with the relay installed, that tells me the diodes are working.
Time to do a carb rebuild.
Thank you for all of your help Don. I will head out to the parts store today to get a new kit. . Looks like i will be out on the lake this weekend after all. . Once again thanks for all of the input. .
I have had a similar problem and one thing I noticed in the design is the fuel pump only operates in one of two conditions with the first being when the starter motor is running (i.e. when starting the motor), and the second being the line from the alternator (i.e. when the motor is running). I noticed this as mine would start great but would soon die so I put my volt meter on the fuel pump and I noticed quite a delay (3 to 8 seconds) from the time the starter was turned off and the alternator power turned the relay back on. In my case, I now suspect my alternator is bad but have not had a chance to check it. Don will know for sure but this is just another thought.
