Esox
- Sep 14, 2006
- 288
Re: Replacing Transom/Advice Needed (Aluminum Hull) w/Pics
I read the same thing about the primer and bonding with aluminum on the seacast site. Seems as though it will work as long as I can dam up the bottom.
I started drilling and cutting out the old wood. Wow is this going to be a big job - not that i though it would be easy. I have maybe a 1/4 of the wood removed. The two peices of wood are stapled together with a lot of staples - the saw and drill bit are not happy cutting through metal. I think the chain needs sharpening already.
Now my main focus is going to be getting access to the thru-bolts on the starboard side. If it involves removing the floor to get to them I'm in for an even bigger job. I don't see any seams in the carpet so not sure if/where the plywood seams are. I'm also not sure what's under the floor - other than foam.
Thanks for all the help guys! I wouldn't have been able to do this without your help.
