water on plugs
This is my first time here, please help me along. I have a 1991 9.9 Evinrude and the spark plugs are getting water on them. First what do yo think it might be? Second if I took it to a shop how many hours of labor do you thing it would be. Third, where could I get a book that will show me all I need to do the job myself? Thanks for you time and patience. dennisthemortgageman@yahoo.com
R.Johnson
Re: water on plugs
You most likely have had an over- heat, resultng in leaking head gashet. Remove head, repace gasket, and therostat, 1 hour. Replace water pump, 1 hour. Test run to check, and adjust, 1/2 hour. 2-1/2, to 3 hrs. labor at shop rate. + needed parts.
F_R
Re: water on plugs
All that and if it has been overheated, the exhaust cover gaskets. They get just as hot or hotter than the head.
kenmyfam
Re: water on plugs
Should check the bores for scoring while you are in there.
jtexas
Re: water on plugs
was there any little silver flecks or anything like that on the spark plugs?
Re: water on plugs
Wow, I really got some help. This is great. No I did not see any flecks of silver in the water on the plugs. I'm not convinced that the problem was overheating though. Last year the motor ran fine and the water pump functioned correctly. This year I took it out and it barelly ran and now won't run. Would a cold weather freeze have pushed a gasket or something? What book do you suggest that I use to rebuild it? Thanks for all of the help.
hoeser
Re: water on plugs
Failed head gasket does not always equal overheating. I replaced one last year that was just rusted, very, very badly. You should be able to replace this yourself with some patience and a torque wrench for the cost of the gasket. I would test run it and check temperature at the head with a temp gun.
Rich976usaf
Re: water on plugs
i might get my hands on a compression tester from auto shop and test the cylinder compression and post the results.
