mystro
Thread starter- Joined
- May 2, 2007
- 142
Unfortunately, my vintage 1972 Seaswirl/OMC Stringer is making an occasional screeching sound that seems to emanate from the from pulleys rubbing against the front motor mount..is the motor is flexing? One of the short bolts holding the motor mount plate in almost pulled out by hand so now I'm suspecting more dry-rot damage but how could water get that high to soak around those bolts and get the stringers wet..I'm a fairly new owner of this boat so I have no history except I do know the foam below the front seat floor was soaked..it drained water for a month, is it possible this boat sank at one point although it did originate from a very wet area (Eugene,Ore) ...as you can imagine I'm hoping it was just accumulation from rain.
Anyway, I guess I'll need to pull all the bolts and exam the holes carefully. If I find dryrot:
Will I need to find pure dry wood in-order to use an epoxy and has anyone seen an online example of fixing this type of problem by chance?
What epoxy products should I look for.
