1994 120 johnson removing lower unit
bwjr99
Hi:
I am attempting to remove the lower unit on a 120 johnson. I have removed all of the various bolts and the unit drops about 1.5" but then appears to be hung up on the shift rod. From other posts I have gathered that there is a bolt that must be removed under the carbs. I can tell the shift rod comes up into the center of that area under the carbs, but it would be impossible for me to reach unless I removed the carbs. Am I missing something? Any help would be appreciated.
Thanks JR
robert.barnes
Re: 1994 120 johnson removing lower unit
i have a 85 120 the bolt on it is under the intake for the carbs i beleive you have to look from the port side to get to it a 1/4 swivil and 3/8 socket should get u in there i use a 6 inch extension to reach mine if u need i will try to send u a pick this evening when i get home
ezeke
You should have a lower cover that is split down the center and can be removed by the simple expedient of removing four screws from the starboard side, then pulling the snaps inside of the lower cowl.
That should take <10 minutes and give you open access to the shift rod.
bwjr99
Thank You Ezeke, I will see if I can get to it that way
bwjr99
Thank you I will give that a try
BWJR99
bwjr99
Hi Robert:
It was right where you said it was, I actually took the incorrect bolt off the first time and that is why I guess the lower unit would not come free. I did not have the extension in my socket set to reach the bolt so I removed the lower cowling as suggested by another member and I got right in there.
Thanks for your time.
Regards,
BWJR99
bwjr99
Hi Ezeke:
Thanks for the info, I took the lower cowling off and that was the ticket. They don't mention doing that in the Seloc Manual and you probably don't exactly need to but it sure makes access a whole lot easier. I could actually see the "mechanics" of how the shift rod was attached at that point and understand how to remove it. Thanks for your time.
Regards,
BWJR99
