OMC Cobra v. Stringer outdrive?
hole-in-da-water
What is the difference between the two when it comes to draining and replacing the gear oil? I was going off of my manual to prepare for it when I realized that the manual I have is for a Cobra, and I have a stringer drive. Whoops on my part (i'm an idiot, you would know that if you read my other posts) Anyways, how different are the two drives when it comes to drainging and replacing? It seems they both have the same drain and fill plugs, but I am not sure if I would miss something in the stringer. Also, do both take the high-vis lubricant? I bought some thinking I had the Cobra because that is what is required. I should be able to take it back, but I would just prefer if I can use the high-vis. Also, can someone clue me in on capacity? I have a 3.0, if that helps. Thanks, any tips are appreciated!
bruceb58
Re: OMC Cobra v. Stringer outdrive?
Which stringer drive do you have? There were a few types. The early ones with the electric shift requires type "C" gear oil.
whywhyzed
Banned
Stringer - 3 separate oil compartments
Cobra - 1 oil compartment
hole-in-da-water
Well, would a year help? The boat is an '86 model, not sure if it is electric shift or not. The plate on the top of the drive identifying it is partially gone and I can't tell. I will be doing the ignition coil on it this afternoon, I can check to see what I have, how do I tell the difference, what am I looking for? And with the seperate compartments, how do I go about changing the gear oil and what are the capacities (if you can tell based on the info I have given)? I have a pump and high-vis gear oil, but like I expressed earlier, will I be needing the different oil?
whywhyzed
Banned
Electric shift was 1964 to 1977. so You can just use Hi-Vis, yes
Manipulator
If you have a large black rubber boot around the back of the drive and attached to the transom then you have a Stringer. Like mentioned, the stringer drive has three separate compartments, the intermediate (IM), the upper unit and the lower unit. The IM has a screw head plug at the top, take it out. On the side of the IM on the right, down kind of low on the IM is another screw head plug, remove it and oil will drain out. I would go to Wal-Mart, look in the marine section in automotive (could also be by the fishing supply) for a Quicksilver gear lube pump. It will make the job a lot easier and less messy. The pump is like eight bucks. Screw the pump nozzle in the lower drain hole and pump the fluid from the bottom to the top. This is how you do it to make sure no air gets trapped in the housing and not enough lube is added. When you start to see it at the top plug hole stop, I wouldn't pump it until it comes out the top but you probably can as you will lose a little when you take the nozzle off the side and quickly reinstall the plug. To help, install the top plug first, this should help hold the lube in the case so it will not drain out so fast when installing the lower plug.
The upper unit will have a plug/dipstick right in the center at the top. Loosen it and then look on the right side of the upper unit and you will see the drain head screw. Take it out and let it drain. Now you fill this just like you do with the IM (pump the fluid up through the drain hole). Pump it for a little while, not a lot, and reinstall the top drain plug/dipstick. It has a mark on it. You can ad some lube through the top if needed to top it off but it gets hard to determine the level as the dipstick will get covered in lube. You will have to wait a little while for it to drain into the housing. Then check again until you are at the right level. Then reinstall the dip stick at the top.
The lower has a drain head screw at the very bottom in the right and one at the top on the right. Take the top one out and then the bottom and let it drain. Again, fill from bottom drain. Fill until it just starts to come out the top. Put the top plug in, then unhook the pump and quickly put the lower drain plug in. The lower will have a magnet attached (part of the drain plug), check it for any metal debris. It will probably have a tiny amount of metal dust from normal gear wear. Clean it off before installing. I use Wal-Mart's Super Tech Marine High Viscosity 80W-90 lube. Works fine. If you get it, buy it in the quart bottle that looks like a standard quart of engine oil. The pump is made for this. If you get the large cylinder shaped jug the pump won't get all the oil out of it (the tube won't reach to the bottom).
Pump...
Gary H NC
The cobra drive came out in 1986,a cobra holds 64 ounces of gear lube.When it reaches the top dipstick fill it to the line on the dipstick without it screwed in,just resting in the hole.Pump very slow from the bottom..
bruceb58
You don't fill a Cobra from the bottom...you fill from the middle. If you fill from the bottom, you will leave an air bubble in the drive and you will underfill the drive.
As an alternate to the OMC Hi-Vis, I would use Mobil 1 GL-5 75w-90.
Boatist
Stringer not made after 1985. Both the stringer 400 and 800 replaced by the cobra. Driver totally different with no parts interchangalbe.
Better start by telling us what is used to trim and tilt your out drive.
Also tell us if it has a big rubber boot all the way around the outdrive or if the outdrive bolts to the Tramsom.
After you figure out what drive you have Some one can help you.
Manipulator
Early 1986 boats had Stringers too. The last of them.
hole-in-da-water
Manipulator is dead-on, thanks so much. I do have the stringer drive. It has the ugly rubber boot and the pre-set trim. I also already bought high-vis lube and a pump, so I am set on that, just needed some clarification on how the Cobra was differetn vs. the stringer in changing the oil. Thanks again!!!
