mercruiser no spark
wildcat8466
I have mercruiser 3.0 have no spark at plug, I checked all voltage at + coil and - coil got 12 volts and even have 12 volts at points with ignition on but no spark at plug, new points and condencer and rotor button what can I do next!!!!
Don S
Re: mercruiser no spark
Is the point gap correct?
Did you check the coil wire (one from cap to coil)
What shape is the distributor cap itself in? especially the button in the center that rides on the rotor.
wildcat8466
Yes it is at .022 like it says and yes there was voltage at the end of the coil wire to. the cap looks in decent shape and the buton is new. was running just last week. now no spark very confused!!
wildcat8466
I am totally braindead can someone just type a list of what to check and the steps you would take to diagnose my problem of no spark at plug
Haut Medoc
Have you changed the cap & rotor?......:)​
Zim
Could be the rotor under the cap is worn, not spinning, and not passing the current along. Might check that.
wildcat8466
have replaced the points ,condencer and rotor button. the button does spin and seems ok
wildcat8466
have not replaced plug wires but it was running last week and now it will not produce a spark at the plug. I have 12 volts at the + side of coil and the - side of coil with the key on. there is voltage at the points and when i ran a screwdriver around the points, it would produce a spark every now and then. I took the coil wire off of rotor cap and it had 12 volts there.I do not have a dwell meter and the .022 that the points are set at is very close and I could only tell that it was working in the dark. would the dwell cause it to not put a spark at the plug????
freddyray21
condensers are known to be bad new out of the box. The points should produce an arc every time they are opened and close. Not every once in a while. Check to see if you have a shorted set of points. From the points wire to ground there should be a direct short with them close and no continuity when open. A shorted set of points won't fire. Did you tune it up and now you don't have a spark? If so put the old parts back in and see if you have a spark. If it ran with old parts and not with new then you have a bad part
Don S
Did you have the points on the highest part of the distributor cam lobe when you set them at .022?
Was the feeler gauge perfectly clean? I watched a guy set his points one day with an oily feeler gauge. There cannot be any oil on the points.
wildcat8466
I did set the points on the highest point and set the points with a clean feeler guage. So does that mean that the dwell is properly set?????
Don S
No, that just means the points are gapped to where it should run so you can actually check the dwell. The dwell is the final test. Then, you have to reset the timing and readjust the carb mixture and idle speed.
wildcat8466
ok I will worry about the dwell when I can get it spark properly any other thing that I can check?
Coors
I don't understand; a coil wire has 12 volts? Is this the plug wire sized wire from the coil to the center of the distributer?
wildcat8466
from the wire of the points to ground I have 5 ohms and the points are open and the coil wire is still hooked up. do you test the ohms with coil wire still hooked up if so I"m grounding out. How could this happen?????
wildcat8466
yes that isthe center coil wire at the end where it hooks up to the cap has 12 volts
That should be 20,000Volts or More........
If you supply 12V to the (+) side of the Coil,......
And touch a Ground to the (-) side of the Coil,.......
You Should get a Spark of 20,000V or More from the Coil Tower Wire(aka. the Big Center Wire)......
Coors
Yeah, 20000+ volts; I'm getting lost on that one.
Don S
How are you measuring the voltage to get 12V out of the center coil tower?
If you are measuring from coil tower to ground and getting 12 Volts, then the primary and secondary windings are shorted internally. You need a new coil.
