Robert16star
Thread starter- Joined
- May 13, 2007
- 14
Today was my first on-water test since I rebuilt my fuel pump. I started with a full tank of gas that I had added a pint of oil to just to be sure I was getting oil from my auxiliary oil tank. I had made a mark on the oil tank and sure enough I did use oil during the day.
I ran most of the time at WOT and all was good until I switched tanks.
About 15 minutes after switching to my second tank (also full, but without oil) (half at slower speeds, half at WOT) the engine sut down. I squeezed the ball and it was soft / empty. I opened the tank for a moment, re-closed it tight, squeezed the ball till it was hard and the engine started and ran. I ran for a few minutes and the engine shut down again. After this I ran the rest of the way in with the tank cap on but not as tight as I usually do and I made it all the way in (both at WOT and at lower speeds) without and problems.
Questions:
1. Should I leave my tank cap something less then max tight while running?
2. Could I have a problem with the seal on the tank cap and need to look at replacing it?
Thanks for you time,
Robert
Questions:
Robert
