FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
What would be needed to be changed to go from a 86 5.7 alpha1 sterndrive to just the motor from a 93? Basically i'm using just the block.Will everything bolt up to the 86 exsisting sterndrive or will i require a new flywheel/coupler?
The heads on the 1993 will have the two center intake manifold bolts at an odd angle, so the 1986 intake will not fit the 1993 heads. (In case you end up needing the whole 1993 long block.)
