Re: Hello, have questions about "Electric Boating"
Its cool.
Woops. I got lazy. Yes, by "pounder," I meant 70 pounds of thrust. Sorry.
Its cool.
Links aren't allowed here, but here is a copy and paste.
http://cabelas.com/cabelas/en/templ...parentType=index&indexId=cat602014&hasJS=true
But, it is gonna run you about 3000 dollars when you count 4 batteries, and all the other junk associated with it (fuses, wiring, etc)
Best bet is to start with a 70 pound thrust transom mount, and go from there.
can you find a picture of something similar on line and post a link. if we have a real idea of the boat you want, you will get the best advice. there is a brand called it thing electra craft boat.
here's a list of manufacturer of electric boats. and there links.
http://www.mindspring.com/~jimkerr1/sebebman.htm
what about a 14 foot aluminum, 24 volt transom mount trolling motor, and put a bimini top on it. think it would give you what you want for a lot less money.
Minn Kota sells an "E-Drive" but is is pretty spendy. I think it has about 120 ponds thrust. They used to sell "Neptunes" that were two 65 pound, 24V troll motors mounted on a rack with a tilt funtion. They needed 4, 12V batts, but were very easy to operate and ran pretty good if you didn't run WOT all the time. I just bought a 20' pontoon boat that had the Neptunes on it and the PO said it ran fairly well. I'm pulling the Neptunes off and hanging a 50hp 'rude on her. I did charge the batts and the TMs still work fine. I think I'm gonna e-bay them.
Ray Electric also sells an electric outboard but it is VERY expensive and uses 8, 6V batts. Not really suited to your needs. But I do see lots of small pontoon boats with electric motor and the owners are very pleased.
i sold that boat, this winter for $1100. as it sits in the picture. it was and old ugly aluminim boat, with weeds growing on it. cleaned it up, $20.00 worth of home depot spray paint. i think the seats were $40 each. plus the trailer, and motor. i had about $550 in it. it would be an easy fun little project, and install a bimini. and a good trolling motor. these little boats are always on ebay.
there are many good boats built very similar, many brands. check the local dealers, and the will rig it just as you want. sent you a PM, with a link to a nice little boat. take them a picture of what you want.
