stalls shifting into forward or reverse
hvac6470
Need some help please? Got a 4.3 mercruiser S# b628000
With an alpha 1 gen 1 S# 0b610213 stalls shifting into forward or reverse
Can see the stall switch make when shifting so I need a new shift cable?
Had the boat 2 years and never pulled the drive. trying to get service
Manual #6 on eBay wish me luck lol. But was hoping I could order the part
Or get an idea on part # and cost for cable, gimble bearing and all 3 bellows,
And anything need like gaskets, Specialty tool needed to do this job
Thanks for the help.
hvac6470
Re: stalls shifting into forward or reverse
thanks for the help got a 3 day weekend next week ill try to get the part
manual and tools by friday and geter done
hullofalottatrouble
follow the instructions get the right tools and parts.. it shouldnt take too long to go do the work..
hvac6470
Ok getting close to doing this little job. Im going to replace bellows,
Gambler bearing, shift cable, raw water pump. This is the list I came up with.
Any thing missing, or any good substitutes for the Lubricants/Sealers/Adhesives?
Good place to get all the stuff online, alternative to Bearing Removal and Installation Tool#91-31229A
Alpha One transom service kit 1973 to 1989 OEM# 30-803097T1
U-Joint Bellow
Mercruiser Exhaust Tubes
Shift Cable Bellow
Gasket Kit
Gimbal Bearing
Water Hose 3/4"
Water Hose 5/8 "
Lower Shift Cable Kit OEM # 19543T2
Water Pump Kit OEM # 46-44292A5
Tools
Shift Cable Removal and Installation Tool #91-12037
Mercruiser Engine Alignment Tool #91-57797A3
Description Part No.3M Adhesive 92-86166-1
2-4-C Marine Lubricant 92-825407A2
Liquid Neoprene 92-25711--2
Locquic Primer “T” 92-59327-1
Loctite 27131 92-809820
Quicksilver 2-4-C Marine Lubricant With Teflon 92-825407A3
Quicksilver Special Lubricant 101 92-13872A1
Perfect Seal 92-34227--1
Engine Coupler Spline Grease 92-816391A4
hvac6470
also do i need a lower unit Gasket Kit or is the gasket in Water Pump Kit OEM # 46-44292A5?
marco1
Hi I am new to the forum
How did changing the shift cable go!
I need to do the same what about costs
Mark
June 10th, 2007, 10:38 PM
Ayuh,.... I haven't seen this poster do much posting since Last year,...
Welcome Aboard Mark,...
You'll be getting Answers in the thread you started...
Don't be expecting much from this Old 1....
