Hi all,
I got a great deal on this motor $500.00, could not pass it up.
The motor is a E60TTLERV 1994. My problem is when I run at WOT it will start to surge. The surges are about 400 RPM down, then back up, then it will occasinally stay down, and not come back up.
I have had the carbs off, cleaned, and every orofice blown out. The guy I bought the motor from had re-built them like a month ago, so the gaskets are good, and so are the needle and seat valves. Floats at level, when I checked them.
My gas line is about 12' long, continuous to the line that has the ball in it.
I have checked for leaks, and did not find any. I have a clear filter and
can see it is still full the next morning after pumped it up.
Not sure what else to check, so please hand out a few of those good ideas I see you guys give.
Thanks in advance...
Thom
Thom
