No Tach - Merc L6
dirtyoldman
I have a 69 Mark twain boat with the merc 160 HP straight six. My tach isn't operating. The guage goes to 1000 RPM;s when the key is off and back to aero when turned on. I know I have the wrong distributor on here, but where does the tach get the signal? Do the guages fail very often?
Coors
Re: No Tach - Merc L6
Tach signal from the - terminal on the coil.
Rhadley
I'd disconnect the wire at the ignition coil and measure resistance between the wire there are on the back of the tach. It might be broken or corroded.
