Bt Doctur
Thread starter- Joined
- Aug 29, 2004
- 19,560
Stbd motor is fine, Port motor with key "on" no fuel pump noise prior to "start" ,motor will crank over,has spark, will not fire.When the "battery parallel" is operated the fuel pump does make noise to pressureize and shuts down.Motor still willl not start.fuel line selectors are on stbd fuel system.Factory wiring.system ,not butcherd up.Never saw this before ,need direction.
Leave pvt message and or # to talk.
