tashasdaddy
Thread starter- Joined
- Nov 11, 2005
- 51,019
compression 130 each, good blue spark 3/8" using a timing light spring to block. also great spark, when grounding plugs to block. manually move linkage to start position. spray fuel mix in carb. also a good dose in the cylinders. no sign of firing off. new starter is turning it over plenty fast.
