After winterising
bijou22
My boat will go back in this weekend after being out of the water since November.
I followed all the regular maintenance issues for both engine and drive (VP 4.3GL Cobra SX leg 1997), and have only the battery left to fit aand fill her up with gas.
Is there any kind of procedure to introduce it back into the water after a long period of inactivity?
RubberFrog
Re: After winterising
If you used antifreeze, be sure to drain it responsibly! Make sure the plugs are all back in the block and manifolds. If not, you'll soon know...
Ayuh,......
If you winterized with Antifreeze,..... Run it on the Muff, On Your Lawn......
That Might Kill your Grass,.... But It Won't Kill My Fish..........
RubberFrog
Come on bond-o... that stuff will leach into the ground water and kill your fish anyway... drain it into the bilge and then collect it via the bilge drain.
njlarry
....And then it goes to the land fill to drain into the ground? Where do all the chemicals go?
bijou22
I never use antifreeze I prefer the dry approach.
Anything else I should know or look at?
Don S
Here's something I put together last year, maybe it will work for this year as well.
Summerization
Well, it's about that time of year again. Time to get the boat out of storage and ready for the new boating season. Well at least time to start thinking about it.
So, what should you do?
Hopefully all the oils, gear lubes, grease zirks , oil & fuel filters, should have been taken care of during winterization. If not, shame on you, time to get it done. Also look in your service manual/owners manual at the maintenance items it suggest for this time of year and however many hours you have on your boat.
Now let's talk raw water pump impellers. On Alpha I style drives, the impellers should have been replaced during winterization while the gear lube was drained and the drive off the boat for inspection of the gimbal bearing and alignment. Other drives with external raw water pumps should have the impellers replaced. Most impellers should last a couple of years, if you have an Alpha I Gen II, you can usually get 3 years with no problem.
Now you know the impeller will not be the reason you are sitting at the dock on a 3 day weekend with an engine that doesn't cool.
Look at your engine belts and pulleys. If they are all rusty, time to take them off, sand em up nice and smooth and paint em with a good coat of enamel. Allow to set for a day if possible just to allow the paint to get cured completely. If the belts are thinned down from the rust, replace them now, it's easier to do now with the tools handy than on the water with the wife and kids watching.
Next, it's time to tuneup the engine. Yea, I know what people say about wasting money on spark plugs when they only have a few hours on them from last year, but they have also been sitting with fogging oil on them all winter, plus your cap and rotor both see a lot more corrosion than in the auto industry. If you have points and condenser, well, there is no doubt you need new ones. The points are probably glazed over and you will be getting very week if any spark., but hopefully it will start with the old ones.
Start the engine and let it warm up a bit and burn off all that fogging oil. When the smoke clears, pull the plugs and do a proper compression test. See link below.
http://www.boatfix.com/merc/Bullet/97/97_25.pdf
The main reason for the compression test is to make sure all is well. Record the readings and put them in your log book or a page in your service manual. Then you can check them next year to see how your engine is doing. Change your cap, rotor, points, condenser, etc.
With points ignition, you want to set your dwell, set your timing and check your advance timing, adjust idle speed, adjust idle mixture. If you have electronic ignition, just eliminate the dwell check since you don't have points.
Now, you know your engine is running properly and set to specs so you get the best fuel economy possible. And with the price of gas the way it is, that is a big plus.
While your engine is idling (on muffs of course) make sure it shifts and steers. You wouldn't believe the number of boats that come into our shop each spring after they were put in the water only to find they can't steer it or shift it.
Make sure you have oil pressure and the temp is staying where it should. Listen for any strange noises, now is the time to investigate, not when the family is on board and wanting to go boating.
Shut her off, and just go over all the hose clamps to make sure nothing was left loose during winterization. Make sure the drain/vent plugs on the outdrive are tight.
Check all the fluid levels (including battery water). Recheck all the battery connections. It's best to get rid of those wing nuts and get standard nuts and use a wrench to tighten the freshly cleaned and greased connections. Might want to look at the other end of those cables as well. Corroded ends are a great way to spend money with Sea Tow.
If you have a closed cooling system, make sure it's at the proper level.
Now, since your corrosion guard product you used to keep your engine nice is probably gone. Time to add another coat.
You also want to check the other boat systems needed. Nav. lights, anchor lights, horn, all Coast Guard requirements. Also check your bilge pump and float switch. Make sure the blower works, it's also required.
If your boat has them, now is the time to check the head and domestic water systems for operation.
Make sure your life jackets and other safety equipment are up to date. Fire extinguishers and flares must be checked.
Now, do your entire cleanup and waxing, you probably won't have to leave anymore greasy fingerprints on your boat this year, because you know all is well right at the start.
Don't forget to check your trailer; it has to get you to the water. Wheel bearings, breaks, lights, etc. all need checked and repaired.
Then all you need is your stickers for the boat, any other license/insurance requirements your state may have and you are ready to go boating.
This is just a basic list and really doesn't have a lot of details. That is what your service manuals and owners manuals are for.
Ayuh,........ I see a Need for another Pinned Thread.........
Very Timely Don......
