115 Evinrude WOT Troubles
msexton
I have a 115 Evinrude at WOT it starts to act as if it is running ou to gas. I have changed the Filters, Plugs, added fuel conditioner, Removed the tank, drained and cleaned it and still haveing problems. Does anyone have any ideas.
iwombat
Re: 115 Evinrude WOT Troubles
Air leak
Fuel pump
Float level
I'd start with that list.
ezeke
Are you using 5/16 or larger fuel lines?
msexton
I have check for air leaks, dont seem to have any. As far as the fuel pump a local mech. told me to have someone pump the bulb went it started to do this and if it started to run than it was more than likley that. I have done that and it does not help. Do you think that maybe it might be a powerpack.
ezeke
You might want to go through the fuel system, including cleaning the high speed orifices and the anti-siphon valve really well, before you start looking for an ignition problem at that level.​
msexton
I also have another question. On top of the fuel pump there is a red knob with what looks to be an air valve stem. What is this.
ezeke
The red knob is on the primer solenoid which takes the place of a choke when you push your ignition key in. When the battery dies, you can manually prime the engine by turning the knob to a right angle from the cylindrical solenoid and squeezing the bulb on your fuel line.​
msexton
Right now the knob is turn pointing strait down. In what position should it be setting.
msexton
On the WOT issue. I took the plugs out to have a look. The two on the port side look fine, the other two are pretty black.
