npd4432
- Apr 18, 2006
- 468
It seems that my fast idle lever is not working. It will move up and down and prevent the shifter from going into gear when in the up position, but it does not move the cables when looking at the carb linkage. It worked fine last year and progressively got worse until it quit. It is also loose with no tension to hold it in the upward position. Is there an adjustment inside of the control box?, may I have some broken parts inside? I have never taken apart the control box, is it a complete disaster to do so, or a fairly simple task. Engine 1983 75 HP Evinrude model #E75TRLCTE
