trim reservoir
mossygo
I just bought a 78 silverline w/ mercruiser 470 and I can't figure out where I need to fill the trim resevoir. Never had an inboard so this is all new to me. Any help would be appreciated. Thanks!
Don S
Re: trim reservoir
Sorry :%
mossygo
Re: trim reservoir
because of the motor or the boat?:'( Thanks for the help!
Don S
Re: trim reservoir
The motor............. Drive is fine, Know nothing about the boat itself.
mossygo
Re: trim reservoir
As far as fluid, wouldn't ATF work?
mossygo
Re: trim reservoir
looks like the trim motor says to use 10w-30 or 10w40. Is the vent screw on the motor supposed to be tight or loose during operation?
Re: trim reservoir
ATF, or Motor Oil is Fine........ Tighten the Screws when you're done Filling it......
