94 oil injected 90 HP
aleutianwest
I have 1994 90 hp yamaha oil injected with no oil tank what would happen to the lower and upper bearings if i premixwd the gas would i be ok or should i look for a oil system
Ray Neudecker
Re: 94 oil injected 90 HP
That will work fine. You should remove the entire system though.
aleutianwest
do they make a block off or should i just make one
aleutianwest
Oh and thanks again. im glad youre a round and share your knowledge because there are afew in this bussiness that dont
deejaycee_2000
well try and find a system in the meantime, otherwise if you can just take the oil pump off and take the shaft out that connect the oil pump put it back together and block off the pipes by folding them in half and tying it well with some cable ties or a small hose clamp ...... hope it makes sense .... was a long day
Ray Neudecker
You can also get a pump block off plate from the dealer for the consumer version which did not have oil injection.
Thanks for the kind words.
