'87 Johnson 70 Powerpack Question
ddcarter3
Finally we are in the break in stage after doing a complete rebuild. Thank for all of the info to help us along.
One of the wires coming from the powerpack to the coil has a busted connector and the boot is falling apart.
Can you buy the connector and boot to fix this or do you have to replace the whole powerpack? If you can, where do you get the connector and boot?
Thanks again in advance,
David
mikesea
Re: '87 Johnson 70 Powerpack Question
I would just use a butt connecter and bypass the plug,sometimes its the easiest way out.Just be sure to shrink wrap or use liquid neoprene to protect from moisture
