1971, merc 115
dan valders
it seems everyone i talk to has this same problem, my carbs seem to just pour fuel out, is there any quick fix?
tashasdaddy
Re: 1971, merc 115
adjust the floats, they will leak when tilted.
Re: 1971, merc 115
Dan, First of all the original foam carb floats were replaced with white hard plastic floats, since the originals would decompose. Next, If the floats are adjusted correctly, and the springs on top of the floats are good, it may be the inle needle. Are your inlet needles leaking? Those motors originally came with a stainless steel fuel inlet needle and a brass inlet needle seat, with a rubber insert. Those were retrofitted with a stainless inlet needle with a neopreme tip and a solid brass inlet needle seat. Make sure yours are not mixed up.
dan valders
Re: 1971, merc 115
thanks, my float was full of fuel, so i chenged that and needle and seat, it seems to have worked , i'm gonna do the other 2 carbs friday
