Early 50's QD/FD gears the same? (FR?)
Scaaty
From what I can tell the gearcase/gears are the same in a 10hp QD, and 18hp FD. 5 bolt case, and I think the years are 1955 to 57 the same? Different case in 58 I think. Anyone add a little more knowledge to this? Thanks
F_R
Re: Early 50's QD/FD gears the same? (FR?)
That is basically correct concerning the gearcases. But I'm not exactly 100% sure if the gears are the same without going to the parts books. Might make a difference from year to year also. Just not really sure about this.
R.Johnson
The 10 HP has a thicker driveshaft, ahd the pinion is keyed to the shaft. The pinion does not ride up into the lower gearcase bushing. The 18HP has a thinner driveshaft, and the drivehaft is splined to hold the pinion. The pinion ride's up into the lower geaecase bushing.
F_R
OK, here we go again. I think we beat this subject to death once before. I believe R.Johnson is referring to the 4 bolt gearcase. Earlier models shared gearcases, FD/QD.
Here is the book, concerning the gears inside. You'all figure it out for yourselves, my brain is too feeble. Except I do see cases where they are shared FD/QD
Chinewalker
As a set, the gears will interchange between most of the 5-bolt gearcases of the 1950s. Also, you can use a set of gears from an EARLY 4-bolt 10/12/14/15 hp gearcase (1954 and prior). Problems arise when you try to mix-and match gears themselves. I have counted at least five different gear configurations as they altered spiral patterns, tooth counts, etc. over the years to achieve better durability and reduce gear noise.
- Scott
R.Johnson
The QD's were made from 1949 to 1963, they were all 10HP. with a four bolt case. The FD's were made from 1956, to 1968. They were 15,18, 20 HP with a five bolt case. The QD's, and FD's would not share part's to my knowledge., and they certainly never shared gearcase's. What part's do you need?
Chinewalker
Just to clarify...
The QDs and FDs DID share gearcases up until 1958, when the QDs got the beefed up version of the 5.5/7.5 unit. A 1956 Johnson FD-10 15hp is the same as a 1956 QD-17 10hp from the bellypan on down. They both have 5-bolt units. A 1954 Evinrude 15hp Fastwin has a nearly identical lower unit to that used on the 1954 Johnson QD-15. (Evinrude did not make a 10, and Johnson did not make a 15 in '54.) They both have 4-bolt lower units that were similar to the 1955 and later 5-bolt lower unit. This earlier 4-bolt unit was completely different from that used on the 1958 and later 10hp models.
- Scott
F_R
Chinewalker got it correct.
F_R
lest there be any further disagreement.
Scaaty
Good info all. I was pretty sure the cases were the same 1955 to 57. Looks like the chart has FD 11 and QD 17 gear sets the same. I have a complete set of good gears from a 57 FD 11 18hp, and a QD 17 56 case coming apart. The bottom fin part look the same. I guess my best bet is to get the Mic out and do some checking and counting.Thanks for the info, much appreciate the time put into the replies!...
