Uh-Oh- Water pump installation off to a shaky start?
NealLauderman
Re: Uh-Oh- Water pump installation off to a shaky start?
Thanks rick! I am still having issues getting the bolt out. Have been spraying them with PB Buster with no luck. Anything else I should try before I head taking it to a machine shop?
rickdb1boat
Now that you can see the bolt, I'd heat them it red hot and let it cool down good and try it again....You might be able to get a small pipe wrench on it for a little more leverage. But try to avoid breaking it at all cost if there is still a nub sticking out. Like I said, the welding of a nut on there may be enough to bust it loose.. For now,.heat it up , hit it with the PB Blaster and then let it sit overnight. Try again and then head to the machine shop if no go...
NealLauderman
Sounds good bud! Thanks! Will keep you updated :)
iwombat
A "blue wrench" (torch) and vise-grips will get most any stuck bolt out. Just heat it red hot and clamp the vise-grip on. Once it starts to budge work it back and forth, slowly out. You may need to reheat it a few times on the way out if it's really corroded in there.
Benny1963
buy you a drill bit set drill small hole dead in center of bolt .
then drill with one size bigger work your way up one bit at a time till
you get to the bit that is one size under the bolt .
leaving whats left of threads then use tap for the bolt size and thred
and retap or chase out what is left of old thread.
i did all 4 bolts on my 150 in one hour .
if you mess up you can buy helicoil kit for your bolt size drll it tap it oversize
and insert helicoil putting it back to orig size .
its not that hard to drillout those bolts as long as you drill pilot hole dead center.
benny 1963
