Used motors 90HP
roscoe
Re: Used motors 90HP
Hola, recepción a los iboats.
Estoy utilizando un programa de computadora para traducir al inglés.
¿Usted quisiera comprar 90 usados que el hp viaja en automóvili, correcto? ¿Qué país adentro le localizan? ¿Qué ciudad adentro le localizan?
Tenemos miembros de habla hispana que puedan mejorar ayuda usted.
Sea por favor paciente. Los miembros le asistirán.
QC
He wants to buy 4 cycle 90 hp Outboards . . . I am better at writing than reading, but I believe he wants this:
Motores ciclo 4 de 90 bhp
Es posible mi espanol es muy mal, pero queres motores 4 ciclo y 90 bhp, no?
kenmyfam
Cervesa por favor LOL
Thats my limit except for gracias when I get the cervesa !!
treedancer
I managed to dig out the 90 hp. When I get some free time I might take a Spanish language class at the local community college.:%
Dunaruna
[colour=blue]Kevin, are outboards measured with BRAKE horse power?
BTW, your spanish is muy bueno!
Texasmark
Dun. Used to be and OMC used to rave about the fact that their engines were OBC "Brake" hp certified.
Well, for those who don't know, don't have a dictionary handy, are curious, and are reading this, "Brake" means that you are measuring the output of the engine at the crank with NO accessories.
Today engines are "Prop" rated which is what we use and need to know, but a long way from the raw engine hp.
Mark
kenmyfam
Quick question.
1985 Johnson 140hp V4
Crank or prop rated ??
kenmyfam
What would be a best guess at the prop ??
roscoe
135
Factor in that the rating system for outboards has a 10% +/- error factor to allow for manufacturing process and model variations, and it could have anywhere from 122 to 147 hp.
That is one reason why any 2 motors of equal rated hp, may perform very differently in the real world.
Now, factor in the real world wot rpm that your motor is hitting.
If your motor was rated @ 5500 rpm,
knock off 10% if you are only hitting 5000 rpm, +10% if you are hitting 6000 rpm.
So the crank vs prop rating factor is far less important (only 4-5%), while proper engine height and prop selection can account for a 20% difference.
kenmyfam
Thanks for that. Very informative and clearly explained.
imported_TonyG
Yes, but I need for repair 4 stroke outboard motors.
Your Spanish is good .
I live in Monterrey, Mexico d:)
imported_TonyG
Thanks, Your Spanish is good.
I need outboards marine motors 4 stroke for repair
roscoe
Hello Tony in Monterrey, Mexico.
I am afraid you will not find a source for motors.
Good Luck in your search.
