Lower Unit Removal Question 60HP Merc
jarosh
I'm going to replace the impeller in my 2003 60HP Merc (Serial Number: 0T680439 Model Number: 1060412AN) and was wondering should I have the motor in forward, N or reverse when removing the lower unit?
Kajun37
Re: Lower Unit Removal Question 60HP Merc
jarosh from KM's? i'd check your manual....my johnson says reverse....when i had my force it was forward...
Rockonafly
My 96 60hp Merc says have it in forward. I always have to reset the shift lever after each replacement and I have done it 5 times. The only caution is make sure you have ALL of the bolts/ nuts out before you try to pull it apart. Mine has one under the zinc skeg. The first time is a bear getting it apart. Good Luck
Rockonafly
mercibby
forward gear!
jarosh
Yep Kajun its me from KM. Damn Water pump went out on my my last trip down the James. Normally I would consult the manual for such things but I have temporarliy misplaced it (aka lost for now). And want to get back on the water asap.
I thought it was forward. Thanks for the replies everyone.
