pontoon chief
Thread starter- Joined
- Aug 9, 2004
- 116
I am working on a 2003 9.9 4-stroke that is having carb issues.This motor is on a boat as a kicker motor to a 115 yamaha.I had to tear down the carbs in the 115 as they were clogged ,dirty,and in some areas coroded.The issues with the 115 solved I turned to the Yamaha kicker motor.Expecting the same conditions with this moror,I removed the carb and cleaned and blew out all passages etc and replaced the carb on the engine.This carb is equiped with the electric magnetic choke were when the key is pushed in the magnet engages the butterfly etc.
Prior to hooking everything back up,I installed a large 10 Micron spin on filter on the boat and hooked up both motors on the filter.
The 9.9 was hard starting but when placing my hand in front of the intake I did get the motor started,but it ran a little rough.I again removed the carb and took my time and again cleaned the carb.Again the the carb was installed back on the motor,this time with different results.The motor starts and idles fine,however it will not accept any throttle without popping,kicking or stalling.When I can get the RPM s raised past the idle,the motor will run great.However when I lower the RPMs the motor will again pop ,kick or most likely stall.
What the heck is going on.This motor is like brand new...\\Patrick
