Lost spark for no known reason late 70's Mariner (50HP)
ba_50
The last time I started this motor there wasn't a problem. It is still on a stand and there isn't any spark on two plugs, probably the third one too.
So if I never hit anything (flywheel key should be ok) and in neutral what else could it be? Thanks.
Laddies
Banned
Re: Lost spark for no known reason late 70's Mariner (50HP)
If we had a serial number, we can help they had a couple of differant systems
ba_50
The numbr on the block is 0244350. That's all there is.
Laddies
Banned
1. make sure the engine is turning at least 250 RPM
2. disconnect the blk/yellow wire at hh the switch box and ck for spark--spark means trouble in the kill circurt
3. disconnect the yellow wires from the rectifier-- spark bad rectifier
4. Ck the stator--need to know if it is a flex plate or cast flywheel to give specs.
ba_50
I don't know what the flywheel is made of and I can't get it off with a regular puller. So no way to check the stator. I don't know how fast it was turning when I checked the Blk/yellow wire and yellow wires but still now spark.
Laddies
Banned
If the flywheel has 2 rings of 1/4 " bolts hold it together it is a flex plate if it is cast in one piece it is a cast flywheel neither needs to be removed to test the stator that is done with a DVA or OHM meter on the wires at the switch box
Capt Ken
With the sparkplugs out, disconnect the black wire with yellow tracer from the CDI, spin the engine and see if you have spark then. If not, its probably the stator on that engine. If it sparks, you either have either a bad mercury switch on the side of the engine or grounded key switch.
ba_50
I disconnected the yellow/black wire on the side of the motor electrical block and no spark.
