FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hello. Is there a special tool to remove spark plugs from this engine? I cannot get the #2 (lower) plug out as the socket (long 18mm) gets jammed against the block...thanks
try loosen and get your fingers in there
if that does not work, loosen a little and get some silicon tube to fit over the plug so u can turn it with the tube
