what if battery gets wet?
rebars1
What happens when a battery get submerged? Does the surrounding water become electrified? Blow up? Just curious, in case my boat should take on too much water. Will the bildge pump continue working if the battery is under water?
Dunaruna
Re: what if battery gets wet?
[colour=blue]If the water is conductive (most impure water is), it will short.
Will it explode????? I doubt it, being underwater would contain the hydrogen gas - I think :(
tashasdaddy
if you are speaking of salt water, the battery will be shorted, and loose charge, if totally submerged. if water gets that deep, you better be calling the Coast Guard. thats why i use a bilge pump with an automatic float switch, it also has an indicator light on the console, so i know when it kick on.
bruceb58
It will discharge slowly...very slowly....if it is saltwater.
The pump will still work.
Just curious...why are you asking this question?
Boatist
Your battery should never get close to going under water. Put it in a battery box and cover with the lid. Use a strap to keep the lid tight and in place. If the hull is leaking fix the leak, In raining season cover the boat to shead water.
Water in the boat is a bad thing. Saltwater damages everything, metal rust or corrodes, wood rots, plus the mold an mildue.
bruceb58
Agreed...if you get water high enough to cover your battery, you have worse problems than worrying about the battery.
rebars1
Hey. I am just asking the question. Once in awhile I read an article about a boat sinking and being recovered, and I was just wondering if the divers get shocked.
Also, If you are in a boat taking on water and are beyond bildge pump help, should you switch the batteries off?
I keep my batteries as high as practical, covered, and strapped down.
tommays
In very general terms anything below 30 volts is safe :)
But with a battery the amps are so high most injuries happpen from Arc burns when your working on things live when you should not be :(
Tommays
KYHunter2
If , for some reason you are thinking , the battery is going to be submerged.
Fix the problem , as stated.
Until then , you can do as I did, as a kid.
I'd pack the battery up and down to boat , every time I went fishing.
Had to to charge for trolling motor. LOL.
KYHunter
ray estep
I just want to know where the on off switch is on a battery. I can't seem find mine?
KYHunter2
Just saw that ray !! Good question. When you find out let me know.
Im going out right now to look for that dagum switch. LOL ! !
KYHunter
rebars1
You don't have a battery disconnect switch on your boat?
ray estep
Thanks for this thread! I learnd some things from it. No I don't have a battery disconnect switch on my boat. I have two wing nuts on the top of my battery. Thanks to you guys I now know to get a battery box and to strap my battery down. I was wondering when I bought my boat recently about the battery just sitting in the bilge area on a piece of wood. Also I'm not going to try this but, I'm pretty sure if you put your battery in water it would ground out on the water and there would be no way to get shocked. Unless you were just hell bent on it. You might if you touched a piece of metal between the posts. If anyone is that curious please let us know what happens. Thanks
Ozarks R&R
waterone1@aol.com
While we are on this subject......any liquid in the boat (when submerged) that is lighter than water will skim on the surface and create a problem for anyone in the area (battery acid, fuel, oil, etc) yes, you may get serious chemical burns from this.
If your boat sinks in salt water(or any water high in mineral content) the several hundreds of available amps from the batteries will cause imediate galvonic corrosion to metal objects in the water. For instance the outdrive, trim tabs, etc that are conected to the boats ground may be damaged and even cause heat damage to the surrounding fiberglass of the hull.
bruceb58
You would not have hundreds of amps.
KYHunter2
Yes, I have a battery disconnect switch .
I don't see what that has to do with the battery being submerged, however.
All the switch does ,is cut off power, to whatever you chose, to disconnect .
As far as I know, the battery is still live and well.
KYHunter
ray estep
I don't know everything but, any volume of water
large enough to sink a boat would sertanly dilute the
battery acid to the point of eleminating any risk of
cuasing burns. Battery acid also mixes with water so it
won't float or accumulate. Gas and oil are not especially
likely to cause burns eather. Unless you just sat in
undiluted gas for an extended period of time it may.
Even then its not likely to burn. The senario put forth
here where gas oil and battery acid present significant
hazard in the case of a boat sinking would have to
involve a collision or an RPG or some kind of major
catastrofy. not just checking out a boat for posible
salvaging. Thanks. Ozarks R&R
